Case Nutty 1660
First pic shows a 35 plus year old hyd line that gave it up on the WWC 37 and one of the 1470 after repair was completed, next two are my "Quick Drill fill" unit my 580CK I can fill both drills in a couple min and beats a drill fill auger hands down (yes I have two of those) then a couple of my Uncle Land Pride side-by side, I used this spring to pick rocks before planting, next are a few of the 74 970 with the 1970 ED drills planting Barley, a few of disc bearing replacement, the VA on one of many jobs she is fitted perfectly for along with the G-16 Case Danuser 8' blade,, smoothing out where some dirt was robbed for flower bed,, next up are a few of the "colors" we have here at times, and a shot of the "Game" I feed year around, this year was a Dry one for us next shots are of one of the dozens of bad wild fires we had here this year, my planting was interrupted by a small snow storm, then it was back to loading out more Barley I had sold, with the ground a bit wet to plant I took a day or so to replace the hyd pump and fix the charging system on this 444 I had sold, then I tilled part of the garden with my 444, enough for now
cnt
cnt
