1070 POWER SHIFT ??
herk
Hello I bought and fixed a burnt 1070 I used parts from a 970 dash gauges ect ( Whole assembly, peddles gauges, steering) the trans temp & oil pressure dose not seem to work , can these be replace with other gauges ?? if so what should the pressure read and what temp should it read , Thanks Bryan
Check your SN's on your 2 machines. There were several different gauge sets depending on years. Sending units much match the gauges.
