2294 torque limiter Belleville spring
Eddie7295
Part # a64370 called Case Ih they wanted over 500$ for it! Key spring in Pa. Can cross ref the case part # and had seven on the shelf for 160$ a piece if anyone out there needs one. 1 800 245 3600 They can also cross ref the Belleville springs in c2and c3 78$ at case 14$ there!
Your welcome, just trying to save a little money thought I would pass it on everyone knows how CNH has got on parts!
You are absolutely right about price of Case parts since New Holland bought them. Used to really tick me off. Then I bought an 850B Deere dozer. All of a sudden the cost of Case parts started to look pretty good. And Deere is horrible about discontinuing parts. An inspection plate that is nothing more than a chunk of 1" thick steel 10"x12" with one hole drilled in it is $600. I have to wonder what value these new Deere tractors will have in 20 years and there is no support because they are "obsolete".
Yes went to the local Deere dealer just the other day because it was close ask for the rubber seals on the top of injector return line four of them cost 10.25$!
