1965 Case 430 LCK
Keith D
New User
Back to top
View user's profile
Keith D
New User
1965 case 430 Reply to specific post Reply with quote
Are there no Case people out there or did I post this in the wrong place? This LCK was 1 of 50 made in 1965. It is gas and was designed for orchard and golf courses. There were only 225 made in the 3 to 4 years they were made so any help would be nice. Thanks Keith
Back to top
View user's profile
Thanks Dick Case has no numbers to how many were diesel or gas. They also don't have any thing on the differant styles
I posted quickly over on the Restoration forum, not noticing you had a Draft-O-Matic tractor.
Someone pulled a switcheroo on you and bolted in an independant PTO for an older Eagle Hitch tractor, as I indicated. The DOM tractors had a very different independant PTO in them with a lever which was mounted vertical, rather than horizontal. You may be able to weld a vertical lever to the hub of the old lever and get buy with the old styled PTO.
The PTO you have also extends further back from the rear of the tractor so that could cause an issue with some pto implements in relation to your drawbar and 3pt arms.
Loren
