DB1200 Selectomatic
VAC400
There is a 1200 DB on auction soon. Can someone give me go and bad things about this tractor. Jerry from Ohio
I myself Love DB's the 1200 is a great tractor, fuel efficient tough as nails,, if they are neglected they can get things sticky/stuck valves, seats and the 3pt won't work but most times a good service and free up the stuck parts and they work fine again, they also have very good gear selection and gearing
They are very economical to operate and as clumsy as they are economical. They don't turn very short.
Concerning if you get a stuck 3 point, my 1200 would occasionally get a small pocket of air in the hydraulic system and would lose its prime, that would render the 3 point not working. I would have to crack the fitting right under your feet that runs to the front hydro pump and start the tractor to let it prime itself again.
