Drug home a roundnose 300
dkeav
Gone and done it now. It's a real jewel too...
Couple questions, is there a source/remake of the grills? Or just hope to come across one in a junkyard.
Do the newer style squared off 6 loop rims work on these centers? Both rims are ate out by calcium.
(quoted from post at 16:24:36 11/12/16) Gone and done it now. It's a real jewel too...
Congratulations.I like my 312 real well.owned it 20 years, second owner low hour tractor.I'm sure your gonna like yours too
You will be hard pressed to find a new (ish) grill for your 300. Don L. has one on ebay. It would be nice to get the mold for the grill and cast it out of ABS plastic or something.
You must have bought a model 311 or 312. I have bought rims from Miller Tire. I don't know about new style rim but you can buy a flat base rim and put you loops on it. Call and they will know what you need.
Alternately if your in farm country and the rim has local wastage around the valve stem you can have it repaired like I just did. Not very cost effective, new rim would have been cheaper if available.
Joe
http://www.millertire.com/brands/Wheel.html?page 11&sort featured
(quoted from post at 19:13:17 11/12/16) You must have bought a model 311 or 312. I have bought rims from Miller Tire. I don't know about new style rim but you can buy a flat base rim and put you loops on it. Call and they will know what you need.
Yep we're in farm country and regularly repair the rims when the valve stem area blows out. Unfortunately the rot is into the loops and bead on these rims so they are beyond repair. I see from your picture though it has the square loop instead of round, so I think that will work fine.
