Main Hydraulic Cylinder On 530 CK Backhoe
KCTractors
Location
Central Wi
I have to put new seals in the main lift cylinder on a 530 CK backhoe. My question is, can I remove the cylinder with-out taking the main boom off the unit Probably a stupid question, just how hard is it do rebuild these cylinders? Any suggestions. I don't have the machine yet!
yes you can remove it with out removing the boom,, lay the backhoe out as flat as you can get it,, dipper cylinder all the way retracted and bucket fully dumped, then you can un pin the rod end of the boom cylinder and then remove it from the boom
cnt
