Imagine my disappointment when I took the valve cover off today to investigate some noisy valves only to discover a thick white frothing lining the inside valve cover.
The manual says it is either cylinder sleeve packing or cracked block. Is there a easy way to determine where it is coming from? Pressurize the rad with air maybe?
I have compression, it doesn't seem to be burning water, there are no air bubbles in the rad that I can see.
Mike
Mike
