I sure could some rewiring my Case 310 round nose ignition switch. Could not find an exact replacement 3 terminal switch but found a 4
terminal universal switch which is marked bat, st, ign, the extra pole is marked acc. On the 300 the wiring goes from {Red} the battery
terminal on the solenoid to the amp + {charge side} The {green} wire goes from the small terminal on the 3 post solenoid to the st terminal
on the new switch. the {Black} wire goes from the coil{ - }post to the ign on the new switch. from the 2nd large stud on the solenoid a cable
runs to the starter. And under the dash the bat terminal from the regulator runs to the [-} of the amp meter as well as a lead for light power
and to the bat terminal on the new switch. when i started the tractor the stater drive stayed engaged and i couldn't turn the tractor off. had
to disconnect battery to shut it down. so do i have something wired wrong or is the switch faulty? Any help would be appreciated. tried to
find a color coded wiring diagram but could not.
