VAC Stockton hitch learned to hate it
old
So I am putting together and old 3 point platform to use for deer season. Just to put this thing on the Stockton 3 point hitch I had to remove 2 bolts so it would go wide enough to hook up the pins. And of coarse these bolts have been on it forever.
Was going to clean then up[ wit hand wire wheel on the bench grinder just to find out I have lost one leg of power going to the shop so now I have to find that problem
Sounds like quite a day for sure. I'm lucky, my Stockton hitch moves freely, am hoping to try to install Eagle Hitch arms on mine in place of the original ones. Sure would help in trying to hook onto 3pt finish mower. You might have only blown a fuse if you're lucky. Good Luck !!
Mike
Not likely to be a fuse since there are none. Now a break ya maybe but I have not run out of water so that is not likely. More likely to be one of the 2 hot wires from the well house to the shop. Those wires have one or more splices in them so likely one of those has corroded again
