Ken Christopherson
Hello everyone,
Well, it finally happened. The ancient repair that was done on the '41 SC gas tank finally started leaking. Being that I have already put a lot of work into this tank, and it is original, I would like to keep it. My thought process is that I will cut out a 2" by 2" square section, and weld in a new piece of metal. I have washed the inside with dawn dish soap (twice), and rinsed with a LOT of water (basically just ran the hose into it and let it run for about a half hour).
I have welded on a motorcycle tank, and when I did that I ran a hose from a running car's exhaust pipe into the tank to try to avoid the horrific explosion. Anyone done the welding on a tank without issue after cleaning it? I'm looking for some pointers here.. I should have done this prior to restoring the tractor, but at the time the old repair was holding up well.
