Case 730 throttle linkage
tak8098
I have a 1961 case 730 gas with a positive shut off rod. I'm missing a piece that goes from the governor rod to carburetor. Does anyone have a picture or a part number of what I need.
I think a lot of us here use the CNH parts store website. CNH parts online, then go to-Search parts by model. Enter your 730 and then select the page using the serial number of your tractor.Then select throttle linkage for spark ignition engines and you have every thing you need!
(quoted from post at 01:33:33 10/18/16) I think a lot of us here use the CNH parts store website. CNH parts online, then go to-Search parts by model. Enter your 730 and then select the page using the serial number of your tractor.Then select throttle linkage for spark ignition engines and you have every thing you need!
I use cnh parts store as well,but the piece I am needing is no where to be found. Kind of an oddball piece with the throttle stop rod.
