Well it's been a long summer. I finally got my 930 with the transmission problems put back together. Everything went together pretty well and seems to work OK. It drives much better with all 8 forward speeds and 2 reverses all the time! Discovered that the slop in the steering was coming from more places than I thought but not difficult to fix. The only head scratcher is the lift arms won't raise unless the engine is wide open. I need to pick up some adapters so I can start checking hydraulic pressures and figure out what's going on there. All the gaskets and seals were new so I'm guessing something is out of adjustment or not set up right. Still need to find an OEM seat.
Eli
Eli
