Trying to find the flywheel bolts part # 08530AB it a 7/16-20 bolt interference fit. Bolt Diameter is.435 same as an aircraft bolt or Hiloc. I followed the specs in the Manual it says torque flywheel 50 foot pounds the book is WRONG stripped at least 3. I thought the bolt was turning in the crank others are probably no good been over stretched. It should be closer to 36 ft lb when I checked the torque by bolt size. Has anyone had this issue before. Anyway I need to find a place to get 6 replacement bolts and nuts. New used whatever any help would be appreciated. A little input would be helpful as well. Heres a link to the bolts
Thanks Byron
http://partstore.caseih.com/us/parts-search.html#epc::mr66945ar131481
Thanks Byron
