Another plow id question
mschwartz
Would like to know the correct model for this plow as well. Determined to try to plow with one of them this fall. Depth wheel appears to just be welded on so most likely not original? Thanks, Mike.
I plowed with one of those when they were new . If the furrow wheel
is adjusted properly , you do not need a gauge wheel . depth is
controlled be the length of the third link ,ones like yours use a
cylinder on top for depth adj while plowing. Good plow ,ours was
on a DC ,both new when I broke them in .
george
