CASE SC AXLE LEAK
Allen L
All my fluid for the Hydraulics leaks out around the wheel axle. Three questions, Where do I get a seal? Is it hard to put in? and I heard of packing some kind of rope or something to stop the leak, any shortcuts? Fair tractor but I don't want to invest a great deal of money if you know what I mean. Thanks in advance for your response.
Allen, this should be the correct modern seal to fit your tractor. The old case part number is 03866AB. They are not to big of a job to put in, the wheel will have to be removed. Dennis
Thank you Kycase1 for the info. Where can I order this seal? I saw SKF on the picture but not exactly sure where to purchase.
Be sure and look for axle endplay, which will give lateral movement to the axle which no seal will hold. More times then not, it's the cause of seal leakage.
