vai ring gear
cookster
i Have a bad spot in the ring gear on my vai can you take it off and flip it over or just turn a quarter of a turn.
Either way would work. Are the teeth worn or mashed flat ? A 90* rotation
has fixed two of them for me.If the teeth are badly mashed , you might
clean them up with a cut off wheel on a dremel or die grinder ....
