Hi
So my VAC was running about 1/2 power. I pulled the plugs and they were wet. I can't really tell if it is fuel that is black from carbon, or oil. It doesn't smell like fuel so I think it is oil. I pulled head off and the gasket seems fine although both the exhaust and intake runners on the 2 middle cylinders are wet. I don't think I am getting any combustion in them. I took the valves out and they seem to be sealing. I had a broken valve spring a few years ago so I had all the valves done at that time including new seals.
How else would oil get into the cylinder if not through the gasket or valves? What else should I look for?
Thanks!
Mike
Thanks!
Mike
