2294 power shift
Eddie7295
Recently bought a early white 1984 model 2294 that will not move. I brought it home did a check of the pressures in the power shift all check out good the only thing the lube pressure when in the second power shift drops to zero you can get 25 lbs if you run at full throttle, the lube pressure is at 60 pound in first and third. Any ideas on what would make lube pressure drop in second and not first or third?
I do not know why lube would be low in second, but if all other pressures check OK it should move in other shifts. If you can put 4 sp in gear without depressing clutch with engine running you could have a torque limiter or power shift input shaft failure. Rod.
It's either the torque limiter or the input shaft the reason it won't move just baffled by the low lube pressure in second powershift! Maybe a bad gasket behind the powershift valve?
