1845 case skidloader
pinball
Has anyone ever replaced bearings, seals in there wheels. I have a leaking seal on my right front wheel. just wondered where you may have bought the parts. thanks norm
I always buy mine through Case,, but bearing's and seals can be bought at your local bearing supply store, they will also have wear sleeves if you need them
cnt
I bought mine thru CASE. What I have found is if you have a seal leaking you also have a bearing on the way out. It isn't a bad job if things aren't rusty.
