1954 Case 500 Diesel transfer pump help
BT in NE
I have pulled the transfer pump off of my tractor because it wasn't getting fuel past it and discovered the little "T" shaped drive pin between the gear and shaft has broken in two. Is this part available anywhere or will I have to make something? It still has the original PSB pump on it and I would like to keep it if possible. I would appreciate any help. Thanks. BT
Thanks to you both. I put a 1/8 roll pin in the shaft and trimmed it down to fit the gear, put everything together and the tractor runs fine now. I still want to try to find the right part but at least I can move it around here if need be.
