Whether a multigrade or straight weight the only engine oil problems I have seen occur is where a young fella put gear grease (90w) in Pops tractor, oops, or a engine with not enough oil, or oil with contamination. Clean oil of the proper specs regardless of the name on the container is more than likely OK. With so many of us using so many different oil successfully just shows most oils are fine as long as we use the correct ones and change them at proper intervals. Most of us will stick with what works for us and that is the way it should be. I use the straight 30w most all the time only because I have had good luck with it, just as others have had with multigrades. I believe in the future straight weights will be phased out. If a problem would occur and you or I would have only the oil to blame, chances are we would be open to trying something different, but until then it is unlikely many of us will change, LOL. Rod.
