I am new to Case's. I have owned a Ford 9n that was converted to 12 volts. I recently acquired a Case VAC that has a Delco alternator and is 12 vdc negative ground. There is a resistor in line to the 6v coil. I would have preferred the 6 volt system, but I'll stick with this for now. I was wondering if anyone has a wiring diagram for this, I have been through the forums, but haven't seen what I need. Everything is pretty much hooked up. Upon receiving it, and getting it running, I noticed there is a single wire running from the alternator to the ammeter, but the other post of the ammeter doesn't run to anything. I use a meter a lot with work, and understand electrical well, I'm just new to this system. I can't give the exact year, as the dash tag is missing.
Thanks,
Thanks,
