case 530ck- where to add fluid for backhoe?
GeneC
New User
530ck- I had to change a hose on the backhoe (model 31)and am not sure where to add the new fluid? I see a pipe plug 3/4 ways up on the right side of the large arm.. but not sure. thank you for any help
the loader frame is the oil tank for the loader and backhoe, the plug on the side is the level, on top there are plugs for filling
cnt
Thank you.. only thing I'm seeing on both tops of big arms is a small (1 1/2") round vent on each one. they spin freely but don't come out. Top of the tractor hood is three tanks- gas/ oil for something? /then radiator. On the side of the engine area down below the choke cable area their is a fill cap for something? about 2 1/2" cap.
I may have misled you a bit,, early production only had a larger level plug and that is where you also add fluid,, I have screwed a street elbow in them and then a funnel to fill, late units and 580 had a 3/4" pipe thread with the vents in that
cnt
