I was noticing new hy-tran leaking and running down the drawbar and I FINALLY found where the leak was coming from. Turned out the steel line/hose from the hyd pump to the regulator valve had a bad spot. It's a good thing I'm fairly tall and thin as there is not much room to work with the wheels set for 30" rows either. Not a cramped job I want to do everyday of the week that's for sure. Strange that the bad spot was out in the open and not being rubbed or hit by anything either. Well the wind grabbed the door outta dads hand a while back and broke the flasher light so I had to take off the roof access to fix that so I put in new stereo speakers while I was at it, these ones only lasted 34yrs Then on to the worn out and broke original muffler. The new one is a Stanley I was not giving CNH $700+ for a supposed original Donaldson, knowing them it was prolly a cheapy just in a CNH box anyways! I have been having that experience/surprise with them the last several yrs. Lastly I replaced the 194 bulbs in the dash with leds, that outta make it easier to see the gauges at night.
Brad
Brad
