Hello all,
I have a CASE S which I took the head off, lapped the valves and assembled the head and exhaust back on. Now, the tractor will only start when the choke is pulled out and there's exhaust coming from the exhaust maifold and a slight gas leak below one of the intake mainifold ports where it connects to the engine block. I had to clean all the heavy dirt, grease, and oil off the head where the exhaust manifold and muffler is positioned, maybe that gunk helped seal the manifold.
Should I use gasket cement. Also what is the proper setting for a Case S carburetor? Many thanks!!!
Rian, Ontario, Canada
