Evening all,
Just finished up (just about) the VAO project that started this past spring. New bottom end rebuild with everything new (crank ground, bearings, etc) started it up the first time about two weeks ago after about a hour of towing it and getting it timed right. Still having a small problem with the starter not kicking the motor over for more than one turn (compression is extremely strong) and other times it will roll it right over no problems. It does hiss sometimes while spinning it over before it fires, Any suggestions? Video and pic attached.
Case VAO idiling
Case VAO idiling
