930 Comfort King Loose Steering
DakotaRose
New User
How would you go about tightening up the steering on this tractor? The steering is so loose that the tractor runs all over when you are trying to drive. Our other tractors have have a set screw to turn in on the worm gear of the steering column to tighten up the steering, but we can't find one on the 930 Comfort King Case.
Thanks in advance.
Lydia
More than likely the bottom bearing in the gearbox is out and needs replacing. Water seeps in around the seal rusting the bottom bearing.
Need to take the steering arm off and take the steering box assembly off and rebuild.
