VAI I am working on picture and questions
old
So got it up and running sort of. Wiring is messed up some so I hot wired it and the starter cable has a bad end on it so I just take the end and touch the battery to get it to spin over. It did fire up after installing new points.
The loader on it from what the tag reads is a Construction Produsts Corp
4345 Imperial Hwy
Lynwood Calif.
Profit Load #1063.
Appears to have been a trip bucket type loader to me.
Problem it with the bucket on the loader the bucket sits a t a 45 degree angle to touch the ground. So I need to figure out what to do so the bucket will sit flat when al lthe way down
Looks a lot like what I have. On mine the tag is on the left hand side and that is where I got the info I posted. The one I have has a wider bucket which probably does not really belong on the loader. And all the trip parts for the bucket are no longer on it
The tag on mine is the same only slightly newer, mine is serial number 1086. The other VAI has a Lull loader, hydraulic bucket and self leveling.
