I have a Case 630 which specifies SAE 10W motor oil for the Torque Converter. Since the Case-O-Matic is common to the remote hydraulics, I want to use a universal fluid in all my equipment. I was told using the general purpose farm store universal fluid is what causes gear grinding when shifting when cold because it's a thicker fluid. That all makes sense.
Using SAE 10W oil will result in cross mixing when common implements are used with other tractors.
Is there a universal fluid that would be more compatible for the Case-O-Matic?
Thanks,
K-Mo
Thanks,
K-Mo
