Hello all, I finally purchased a tractor last week. Was a local Case 1175 with a Great Bend 660 Loader. 48xx hrs, paid just under 5K for it. Over all a nice clean tractor but its not without its issues. I wanted to ask about a issue I'm having with the gauges. The lower left gauge I believe is the Transmission Temp gauge and it seems to have a bit of a bounce to it. Some times it reads just at the hot or red line and other times its staying in the middle. I am unsure how to check the trans fluid if anyone can point me in the right direction. Also the Engine Temp gauge was working two days ago and now nothing. Gauge issue? Are these gauges mechanical or electronic?
I'm going to add that I wasn't working the tractor very hard. The duals are on right now and I was pulling a 14' ft John Deere BWA Tandem Offset. 1st Range and 4th Gear. Running about 1800 rpm and 4mph.
