[email protected]
New User
I purchased a really nice Case Vac 1951 off Craigslist. The seller was the second owner. The lift was stuck up and would not drop. I purchased regardless and brought it home. Since then I have added a new exhaust, rebuilt the carb, and added a new sediment bowl. The tractor runs great. My issue is the lift will lift, fast and strong, but once up, leaks out from under the control lever when I put the lift down. Not only do I lose fluid, but it takes forever to lower. The hydraulic pump is good, but I am not well versed with the lift cylinder or depth control block. Has anyone else had this issue and or resolved it?
