Well I now have it all set up I think. I will work on getting it running again before I try to install the pump and all the fittings. Tractor has been sitting a few years so I know it will nee the point cleaned and maybe a few other things. Have all but one cylinder soaking with ATF and will get some ATF in the last cylinder before I try to spin it over. Once I get it up and running I will move it to the shop so I can cut out and repair a bent cross member on the lift arms.
I do need to put 2 hose clamps on before I install it
