ok so I went this morning and looked at the tractor..sheet metal pretty good grill screens decent..paint not to bad...looks like it has pwr steering(hyd lines run to in front of engine)...new rear tires..(13.6x36) adj wide front new rebuilt carb..tractor starter doesn't work..tried to pull and the clutch doesn't work to hold the transmission..i looked and the linkage goes to a hyd valve (same place the 2 hyd lines that run to in front of the engine are) so im assuming it has to be running to charge the hyd system for the clutch to operate?...I looked on youtube and didn't find any explanations on how this is supposed to work...also the lever on the right of steering wheel doesn't move..im assuming again it wont without hyd system working?...it has the eagle hitch which I don't know whether it works or not..and also the drivetrain so where would this be valued at?. is this just a chance taker that everything works without it running?...it does have a lever that says L and D in front of the shifter I assume that's direct and low...its gas by the way..any direction would be helpful...just don't know enough about the case-o-matic to be able to make an educated descision on it..thanks for any input
