SC DC Case top link Case tractor
Bhunt
Seen someone out there recently looking for a top link. Saw one on ebay just now new post there proud of it 200$ If your still looking
Best of luck
Byron
The prices for those top links seem crazy, I have a bunch of
different top links for various Case tractors, maybe I should
sell them and retire. Lol
Ben
case top links and brackets sell good. I went to a local auction five years a go. The guy had four late DC tractors. The
auctioneer sold the tractors first. Then the brackets and top links. There was not a link or bracket that sold for under $100
each.
What does one look like?Ive got a bracket on one side with a hole through it and don't seem rugged enough to me.I was wrong once before suppose could be wrong one more time,maybe. Hoss
The SC and DC have 2 top link mount positions depending on whether the pto is needed when hooked up to a mounted implement or not. There is the high point mount(for pto use) that bolts down to the transmission housing just under the seat. The regular mount is on a cast PTO guard that mounts on the pto housing with nuts on the 4 studs that stick out typically.
(quoted from post at 14:34:17 09/11/16) Bhunt, ive got the one on the right.Seems kinda lite to me though. Hoss
You should have both I'm guessing your talking about 1952 and older but you can make one. The orange bracket replaced the one you have under the seat. Its picking up 4 bolt holes it was made for an auger but I have used it for a toplink bracket. I bought an original bracket that covers the pto used broke it within 2 weeks. Hence the new gray bracket.
Lots of ways to make it better. Best of luck Byron
