VAI hyd pump fittings?? got them about licked
old
Ok so Brad sent me the ferule fitting I needed.
I then had to find the correct size pipe and the ferules for it. That proved to be a hard thing due to being 3/4 inch.
If I use a true hyd hose and fitting for the suction hose it will cost me $50 plus. So I figure I can use 1 inch barbed nipples and hose clamps which should save me around $30 and work just fine.
Pictures show all the fitting I had to come up with to get it so I can get this VAI all set up to work and use the loader on it.
But once I have the hyd figured out and working I have Fix a bent part of the loader and then find a hyd cylinder for the bucket
First picture show it all together and 2nd should all the different fitting I had to find
No pictures at this time. I got this VAI a number of years ago but due to other things going on did not get any thing done to it. But now that I got a bit of time and finally found a hyd pump for it I figured I would try to get it back up and running.
Been spending a lot of time working on a JD 1020 also and if I took picture of it you might wonder what went where since right now it is hanging form 4 chain hoists
After letting some ATF soak in the cylinder for a few day I set a battery on the VAI and put in a new set of point and hand choked it and hot wired it and it fired right up. Radiator is a bit low so letting it cool off some before I add some antifreeze to it. I'll then go out and drive it over to the shop for the hard stuff
