Ok so Brad sent me the ferule fitting I needed.
I then had to find the correct size pipe and the ferules for it. That proved to be a hard thing due to being 3/4 inch.
If I use a true hyd hose and fitting for the suction hose it will cost me $50 plus. So I figure I can use 1 inch barbed nipples and hose clamps which should save me around $30 and work just fine.
Pictures show all the fitting I had to come up with to get it so I can get this VAI all set up to work and use the loader on it.
But once I have the hyd figured out and working I have Fix a bent part of the loader and then find a hyd cylinder for the bucket
First picture show it all together and 2nd should all the different fitting I had to find
