This message is a reply to an archived post by hondaracer2oo4 on June 26, 2012 at 19:30:08.
The original subject was "Case 430440 Leaking brake shaft seal".
So, I also am working on a 1966 440H with leaking brake seals..
I have pried off/wiggled/jiggled the brake plate, but it only comes out about 1" so far.
I guess this is not the way to replace the seal. It looks like I need a puller/slide hammer to get the old seal out I see there's a simple way to replace the lip seal that doesn't require removal of the brake plate and seal housing...
If I want to remove the big brake plates to replace the o-rings and the brake shaft seal, what is the preferred method? I worked for a Case dealer back in the day, but didn't remember this particular detail.
