case vo carb linkage
chris1030
New User
hi was wondering if any could post a pic of linkage for carb and govenor on a case vo also wondered if pto seal is still available and how hard it is to change any help would be appreciated
You can get PTO seal from any bearing supply. Just take 3-4 bolts out and pull PTO cover off tractor and remove seal to get bearing number. Easy fix. I have a couple VACs but not sure linkage is the same. Dick
