VAI hyd pump fittings??
old
Thanks Brad for the pump.
Now I need to figure out what type of hyd fittings are on this pump so I can install it and get the hyd system plumbed up so I can get the loader up and working. I know I am going to need to cut out and replace the front cross bar on the loader frame due to the fact it is bent badly.
Thanks
Probably going to use a VAC to pull the VAI out of the weeds where it has been sitting for a few years. I have to make sure to miss the walnut tree that has grown up right next to the front wheel
The High Pressure line (the smaller one)hole in the pump is pipe thread. The larger hole is the suction side and the pump housing is machined for a compression fitting with a brass ferule. The early tractors used a copper suction line. Nick
If it still has the steel lines on it the larger line should have nut 1"-18 threads per inch, and farule that will thread right into pump,the smaller line has nut 3/4-16 threads per inch and farule that threads into a fitting that has 3/8-18 NPT on other end that threads in small hole in pump. The old one is still on the line here. I can take off and send you if you need.
Brad
I may end up having to have you send it since so far I have not found a fitting but will try another place tomorrow and see if they have a ferrule type fitting that will work. Being the suction line I know I do not have to worry about pressure
I sent you an e-mail today about that fitting for the hyd pump I got from you.
