2290 powershift
442
Iwas on here earlier with a powershift problem;no hydraulica when in 1 or 2 powershift,works fine in 3 and "R".Was informed I may have a leakin C1 circuit.Took apart C1,seals and clutch good,supply pipe seals good.I'm wondering where to look next.Any suggestions will be appreciated.Thanks for reading.
The common clutch used in 1 and 2 is C-1, and it is not used in 3 and rev so that would be the one to suspect is leaking. I would assemble C-1 and then pressurize with air to make sure nothing is leaking. As long as the tractor is apart I would check C-2+3.They are used in 1 and 2 also, and in 3rd. which works OK for you. The control valve could have a leak, but I have not seen that problem yet. Keep us informed, Rod.
Also check the C1 feeder tube closely as they are plastic and will split which is hard to see. I always get the old style tubes from salvage/Elmer's when doing a powershift.
