30/70 series pto swap?
MattLF9
I have no experience with the 70 series tractors.
Could you bolt a 70 series pto housing on a 1030 so you could have a quick change 1000 rpm shaft?
Sort of, they bolt on but need some changes to make the clutch work. There is a guy in one of the Dakotas that sells a kit. And you need a housing from an early tractor with the older style clutch.
