2590 seat recommendation
Dave F
The suspension without fore/aft isolation is killing my back and neck.....it couldn't be anything to do with me aging......
Is an isolation kit available or should I go all out and replace the whole works? What do you recommend for air seat with fore/aft? will one from a magnum fit?
Thanks
I have the Magnum air seat in 2390 for 20yrs by now and had put the same one in the 1640 we used to have. I would do it all over again and currently looking at one for the 2090. K&M is where the I have gotten them before and more than likely will again. The couple Magnum ones that I had put in were $1200 seats. Rod can probably tell you the exact part numbers and prices of the ones he has been putting in the 1370s recently. Just be careful as they are kinda awkward/heavy to handle in/out the cab door opening.
Brad
K+M have a nice selection to choose from. My advice would be just to call them and talk it over as they can explain the options and cost of their different seats. Very helpful people, Rod.
At one time Case sold an isolator to give a bit of back and forth movement to the seat. I installed one in my 2290 years back. A neighbour seen it and bought one for his John Deere! I doubt if they're available through parts anymore. It helped quite a bit but a new air-ride seat would be a big improvement. Looking at the mounting of the air seat in my 7120 I don't think it'd be too bad to change your 2590 over to one from a Magnum.
