semiller72
This pic was taken just before I put the dash and plug wires on. Another tidbit for us case-o-magic owners. While I was fixing the cooler line I had a plug in the COM cover and a cap on the hose at the radiator. And she did not move. Not even a bump in 1st low direct drive. I was mighty depressed, thinking I'd have to split the tractor again. I got to wondering - with the cooler line off there was no return back to the COM and it probably couldn't build pressure for the converter. Sure enough, when I got the cooler line back on we have case-o-magic in action. I suspect if you're going to try and run without the cooler lines they have to both be off. Don't think I'd want to do that for too long or under much of a load. I can't remember all your names but I sure want to thank those who have given me help and advice and parts over the years. John Saeli, Don Livingston, and more! I still need an air cleaner, and another rear tire...but she runs and moves.
