Case special tool
1948 mm
I have a case special tool part nnumber G13503 sleeve. Was just wondering what it was intended for. Loooks like a guide for installing a seal. Thanks
(quoted from post at 22:21:03 08/11/16) I have a case special tool part nnumber G13503 sleeve. Was just wondering what it was intended for. Loooks like a guide for installing a seal. Thanks
G13503 is a sleeve that you put on a shaft with splines or other surface that can cut the seal, slide the seal on the sleeve and use a driver to push the seal in the housing. Used on 300/300B differential shafts, utility model flanged axle shafts and undoubtedly other shafts of size and tractor models.
Joe
