Hard Starting 188D - Any Suggestions?
Hi I have an older 480CK. The injection pump went out last year and was rebuilt. It then started and ran excellent. Now, it is impossible to start even in 90 deg. temperatures. When the starter turns over it turns the engine quickly and fine, but it will not even put out any blue or gray or black smoke when being cranked. It acts as if it is not getting any fuel while being cranked over to start. Fuel flows through the filters and if I crack open a line to the injectors I get fuel flowing. However, if I give it a shot of either, it will kick over and start quickly. When it runs, it runs perfectly with no smoke, lots of power, no missing and no blue or black smoke. Any suggestions of where to look to try to fix this?
Thanks.
If it is not puffing out white smoke while cranking it it not getting fuel delivered to the cly's. Sounds like the pumping head in the injection pump has excessive wear. By getting the engine to fire on starting fluid the rpm's of the injection pump are increased enough to help the pump deliver fuel better by not giving it as much time to leak by the pumping plunger. Anyway, that is my two cents worth, Rod.
Thanks Rod. I am thinking the same thing - it is not getting enough fuel to the injectors. However, the injection pump was just rebuilt last year. I will call the fellow that did it and get him to look it over.
Thanks.
make sure the fuel shutoff cable has not slipped and is moving the fuel shut off control fully to the "on" fuel position,, even a small amount will short them on fuel and cause this as well
cnt
Thanks, that was the first thing that I checked. No, that is not the problem. Can the pump plunger that Rod referred to be checked without taking out the pump?
To test the pump correctly it has to be removed and run on a test stand. I remember a fellow having the same problem as you. He would pour ice cold water slowly over the pump to cool it down and then it would start. I guess that would thicken the fuel a bit and then the worn plunger could pump it better. Rod.
