On the lower left hand side of the hyd control there is a speed regulator valve. the hose from this valve runs to bottom of the 3 point lift cylinder. To slow the drop loosen the jam nut on the valve and turn the screw on the end of the valve in, the owners manual says 1/4 turn at a time to increase the drop speed turn the screw out. There is supposed to be a limit stop to prevent the screw from backing out all the way.
you're welcome if I knew how to post a picture the owners manual had a picture that was worth a thousand words as they say.
(quoted from post at 18:10:58 07/29/16) you're welcome if I knew how to post a picture the owners manual had a picture that was worth a thousand words as they say.
This one?
