milt555curl
have an 870 case. Was working in all gears and reverse. a little slow to respond, had to let it warm up a bit. Now I only have 2nd range on all gears. Hard to get into gear. Let out the clutch and it's off and running. no reverse. It's like it's stuck in that 2nd range and won't release. Have to sometimes shut it off to get it out of gear. No one around here that is real knowledgeable about power shift. The powershift was supposedly done just a couple of years ago. Any ideas? Mechanic says pressure gage reads good when he tries it in each gear except reverse. Does try to start moving in reverse but feel like it's still trying to go ahead too
