1945 DC4 has noise coming from the rear axles that has progressively been getting worse. Sounds like really dry or worn out bearings. Also vibrates the tractor a fair bit and rattles your teeth. I greased the fittings on each axle but that has not made any difference. Really bad in fourth gear, not too bad in third, pretty much not noticeable in second.
Are these bearings hard to change? Are they even available? Tractor doesn't get much use, not sure if that is what caused the problem.
