r.w.b.
low hours . its getting its first component repair from the day it was built.other than natural items oil changes batterys valve setting ,its got to get new piston o rings.not bad for 60 years
yes.this is the nicest tractor in its size and vintage to operate,i used it haying a lot,9 foot john deere number 9 trail mower .fit fine,and I bailed a lot of straw with a 275 hew Holland .it was perfect for the job.and planted with a 494 jd planter ,drilled with a 21 -7 jd 8300 drill.i had bigger tractors but those jobs it fit perfectly
Great pictures. The little roundnose really survived the years in nice shape. Very nice little tractor. Bob
Thank you.that tractor was used to mow, rake n bale 80 acres, all it did till the old fellow retired.he filled every compartment full of oil and every month he poured oil in sparkplug holes.set that way in his barn 10 years.he sold farm and moved to town.traded all machinery n tractor in on a new jd compact tractor.I spotted it n then went n was told its history by the owner.I bought it n when it got home I bet I drained 25 gallons of oio.new oil filter n oil new points plugs comdensor cap bug wires n new battery she fired right up.smoked couple hours n she hasn't gave a minutes of trouble till this year rockshaft piston seals went bad no bigge for 60 years old.and IM THE ONLY 1 THAT DRIVES IT
She is a dandy. It looks like the tin is all straight, and in good condition with a nice set of tires. A triple range with 36" rears make a speeding ticket a risk when going through town.
Thanks for sharing.
